Im trying to understand how the “mean” calculation in various panels work. It seems as though it works off the entire data source / query, and doesn’t respect the time window filter.
In other words, if i setup a “Stat Panel”, and choose some data, maknig the calculation baed on “Mean”, it shows the mean of the entire window. WHen i change the filters, the mean doesn’t change, but the graph / data does. I expected the Mean to also change.
Can someone advise how i can make this happen? Do i need to have a seperate query?
SELECT
Timestamp AS "time",
b.Name AS App,
ErrorPercentage
FROM Metrics.dbo.Errors a
INNER JOIN Metrics.dbo.Apps b ON a.AppId = b.AppId
ORDER BY Timestamp ASC
SELECT
b.Name AS App,
ErrorPercentage
FROM
INNER JOIN
WHERE
$__timeFilter(Timestamp)
ORDER BY
Timestamp ASC
