9.1.2 OSS, Under Windows Server -
I have a Table data from a SQL database that shows queue stats from my ticketing system, for each queue I have the unassigned, assigned and pending ticket states
I want to be able to select what color will be set to each element/status in a stacked bar chart
I though that with 3 overrides, 1 for each of the 3 states, I could set the color with a value mapping and then setting for all values the same color -
What happened?
I don’t have any options to change to color in the bar chart override -
I expected to be able to have an override for the color
A piece of the table:
The query:
SELECT * FROM view_queue_status
WHERE ticket_new>0 or ticket_locked>0 or ticket_pending>0
order by ticket_queue -
Bar chart | Grafana documentation
I searched for hours the community because the Bar Chart page does not reference any color override/selection apart from the color palette
