Graph panel - multiple colours/attributes for one bar
Hello!
Is it possible, to have a bar chart with multiple colours in one bar?
I’m working with Grafana v6.0.2 and PostgreSQL
Thanks in advance!
Stephanie
Do you mean the stacking option?
https://play.grafana.org/d/000000012/grafana-play-home?orgId=1&fullscreen&edit&panelId=5
Yes. But I’ve got on the X-Axis Series and not Time.
This is an open feature request but the core team is not planning to build it in the near future.
This doesn’t help you now but our plan is to create new panels visualizations rather than add features to the graph panel (like the new bar gauge panel). The main focus of the graph panel is time series data so we will probably build a separate bar chart panel that works well with non-time series data.
