im trying to create grafana with multiple bar chart and failed to do so.
my goal is like that -
X-Axis will present test name and Y-Axis the results for the test fir each version.
something like that -
no mater which SQL i used, i failed to get this, any advise / guide will be appreciate.
Welcome @eladbren !
There’s a really great YouTube tutorial that goes over how to create a multi-series Grafana bar chart. In the video he shows you the original source data, what the panel expects, and how to wire things together. Hope this helps
Welcome
What version of grafana are you using?
What data source are you using?
Please share your query?
Hi
Version 9.4.7
My data source code is PostgreSQL
And this is my query –
with elad as(
select throughput, version, test_name, gw_ip, gw_name, gw_model,
dense_rank() over( partition by version order by throughput desc)
as “rank” from test_results tr where test_name= ‘waf_krp_https_gen1’
select distinct version, throughput, test_name, gw_ip, gw_name, gw_model
from elad
where rank= 1 and gw_model = ‘X8520’ order by version ASC
thanks,
What does the result of that query look like in pgadmin?
