Hello everyone,
I would like to know if it is possible to change the bar colors in a panel that are resulting from multiple queries.
I am measuring daily energy consumption and would like to see when consumption has exceeded certain thresholds. So far I have managed to get the graph to display as follows:-
The queries I have used are:-
SELECT max("value") FROM "$" WHERE ("entity_id" = 'energy_cost_daily' AND "value" < 7) AND $timeFilter GROUP BY time(1d) fill(none)
SELECT max("value") FROM "$" WHERE ("entity_id" = 'energy_cost_daily' AND "value" <= 5) AND $timeFilter GROUP BY time(1d) fill(none)
SELECT max("value") FROM "$" WHERE ("entity_id" = 'energy_cost_daily' AND "value" <= 4) AND $timeFilter GROUP BY time(1d) fill(none)
The data is as follows:-
Ideally, I would like for anything below 4 to display as green, anything between 4 and 5 to display as yellow and anything above 5 to display as red.
I have tried using series overrides but the only value that seems to be available to customize is 3 instances of $.max. As soon as I override one of them, the entire bar changes to that color.
Any ideas?
Thanks
