Can anyone guide me how can we implement business intelligence using grafana ?
I think that you are on the wrong way, grafana is for monitoring, for time series problems…
if you are looking a free tool for BI, I can commend these projects:
there are more, but i recommed these
Thanks Daniel, I will check the recommended ones.
Regards
Ishtiaq Shariff
Within GrafanaLabs we use Grafana as a BI tool for internal analytics. See this blog post for a summary:
Also check out the new Grafana BigQuery data source, and join the #business-intelligence channel on the Grafana Labs Community Slack
