How can my backend plugin access configuration from the grafana.ini
    • For development: Dockerized (linux) Grafana of version 8.1.0
    • Getting a secure configuration value (i.e. “secure_only = true”)
    • I want to read this value from the grafana.ini file
  • What happened?
    • My backend plugin does not seem to have access to this configuration
For reference: I am the maintainer of the already existing and working SQLite plugin. So I have a working plugin, but just need to add a new feature.
Hi @frser
Generally speaking plugins can’t access values from grafana.ini unless explicitly passed to them by grafana core.
If the user sets under its configuration a [plugin.$pluginid] section it can be used to pass specific configuration to the plugin but this doesn’t work too well in Grafana cloud and you can probably achieve much better results via the configuration form of a plugin.
Do you have an example repository or documentation for that? That would be very helpful
In my case I have a security related configuration that should not be available to people creating data sources in the UI
take a look at Configure Grafana | Grafana documentation
Thanks. I saw this option but could not get it working.
Are you aware of any open source plugin that uses such a configuration so I can check how they do it?
Not in the backend that I can find. the grafana image renderer is using them in the frontend.
Yeah, that is the only plugin I could find using this.
But with the backend plug-in I cannot seem to get this information…
The [plugin.<pluginid>] in grafana.ini configuration does appear in the backend plugin environment variables, (but not passed to the backend plugin via PluginContext).
If you have a section in grafana.ini for your plugin:
    [plugin.MyPluginID]
    setting1 = something useful
    setting2 = maybe useful
You can see those values in the plugin backend via os.Getenv() (and friends).
They appear as GF_PLUGIN_<upper-cased setting-name>. E.g.
    import "os"
    value, exists := os.LookupEnv("GF_PLUGIN_SETTING1")
This would be nice to add to the grafana.ini documentation.
I just tested that, grafana 11.5.3 (in development mode, i.e. docker compose up --build). The parallel access in the front-end seems to take more steps…
