Grafana.ini configuration
Hello All,
can someone help me with the grafana.ini configuration ? i am not able to see web page.
help me with the properties need to enable in grafana.ini and values.
Regards,
chaitanya chordiya
Hi there - you must have Grafana Server Admin permissions on a self-hosted Grafana instance to get to the .ini configuration file: Permissions | Grafana Labs
Hello @anon80964540
i have installed grafana by root user and yes i have the permission to access grafana.ini conifiguration file.
Gotcha - check the provisioning docs as there are some differences in config file location depending on packages used to deploy Grafana: Provisioning | Grafana Labs
