Setting of grafana.ini (https)
I want to access Grafana via https
It does not work with https setup.
When I restart grafana-server, I get an error and it does not start.
The required setting is recognized as editing of grafana.ini and it is already set.
vi grafana.ini
# Protocol (http or https)
protocol = https
# https certs & key file
cert_file = /etc/httpd/conf/ssl/server.crt
cert_key = /etc/httpd/conf/ssl/server.key
The log is described below.
■systemctl status grafana-server.service
● grafana-server.service - Grafana instance
** Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: disabled)**
** Active: failed (Result: start-limit) since 火 2017-08-01 14:22:11 JST; 197ms ago**
** Docs: http://docs.grafana.org**
** Process: 19658 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE} cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${PLUGINS_DIR} (code=exited, status=1/FAILURE)**
** Main PID: 19658 (code=exited, status=1/FAILURE)**
** 8月 01 14:22:11 systemd[1]: grafana-server.service: main process exited, cod…URE**
** 8月 01 14:22:11 systemd[1]: Unit grafana-server.service entered failed state.**
** 8月 01 14:22:11 systemd[1]: grafana-server.service failed.**
** 8月 01 14:22:11 systemd[1]: grafana-server.service holdoff time over, schedu…rt.**
** 8月 01 14:22:11 systemd[1]: start request repeated too quickly for grafana-s…ice**
** 8月 01 14:22:11 systemd[1]: Failed to start Grafana instance.**
Hint: Some lines were ellipsized, use -l to show in full.
■tail -f /var/log/grafana/grafana.log
t=2017-08-01T14:22:10+0900 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, open /etc/grafana/grafana.ini: permission denied%!(EXTRA []interface {}=[])"
t=2017-08-01T14:22:11+0900 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, open /etc/grafana/grafana.ini: permission denied%!(EXTRA []interface {}=[])"
t=2017-08-01T14:22:11+0900 lvl=crit msg=“Failed to parse /etc/grafana/grafana.ini, open /etc/grafana/grafana.ini: permission denied%!(EXTRA []interface {}=[])”
I want to know the cause.
Please let me know if I have any missing settings.
The log output error is pretty clear :slight_smile: the grafana user running the process does not have permission to open grafana.ini, when you change it you must have changed permissions for to file
after changing the permission, still getting the same error.
How to change the permission to access grafana.ini file. Actually I want write permission to grafana.ini file in my case to update smtp settings
@pasarisrushti10 That depends on your operating system. I recommend reading FilePermissions in the Ubuntu community documentation.
If you just want to change a few lines, open a terminal, run sudo nano -B /etc/grafana/grafana.ini, make your changes and save by pressing ctrl+x, y and enter to close the editor. The -B makes sure Grafana saves a version of your file from before your edits so that you can go back to that version if you accidentally corrupt the file (with sudo mv /etc/grafana/grafana.ini~ /etc/grafana/grafana.ini). If you do any of these steps wrong, you may break your Grafana installation, so I’d proceed with caution unless you feel sure about what you’re doing.
Good luck!
Thanks @anon349787 for the reply.
