How can I "unhide" a hidden variable?
How can I “unhide” a variable? I have previously marked a variable or its label as hidden. The Hide menu doesn’t include an option to reveal the variable. Is there a way to reverse this without resorting to creating a new variable?
We are using Grafana v8.1.8 (52edcff798).
The only way I found is to go edit the JSON Model. Scroll down until you find the variables (they are close to the bottom) and then change the value for the “hide” attribute from 1 or 2 to 0
