Hide a variable from showing in the dahsboard
Is it possible to create a variable but it doesn’t show in the dash itself?
The reason is I want to use the variable in the title/description, it’s useless to be shown in the dash itself and confusing.
Yes, In variables settings change:
Hide: variable
Thank you, now I look like an idiot :slight_smile:
But also, I would like to extend the question to a suggestion, if we could have a panel for variables only, just like the one for dashboards, where you can list variables, hide some, customize it, which potentially you can have multiple variable panels for each other panels if that makes sense.
