I set up Grafana Agent v0.36.1 months ago and am not sure which mode it is running in, Flow or Static.
I asked Grot “How can I tell if I am using Grafana Agent in Flow mode or Static mode?” and it replied with:
- Configuration file: Open your Grafana Agent configuration file and look for the
modeparameter. If the value is set toflow, then you are using Flow mode. If the value is set tostatic, then you are using Static mode.
But our configuration file doesn’t specify a mode parameter.
- Command line flags: If you started the Grafana Agent using command line flags, check if you specified the
--config.format=staticflag. If this flag is present, it means you are running the agent in Flow mode using a Static mode configuration.
The command used to start the Grafana Agent doesn’t have the --config.format argument.
Additionally, you can also check the logs produced by the Grafana Agent. The logs in Flow mode will differ from those in Static mode. If you have access to the logs, you can look for any indications or messages that mention the mode in which the agent is running.
When I go to Grafana Cloud and the provided Grafana Agent Logs dashboard it’s empty.
Please note that the Grafana Agent Flow UI is only available in Flow mode, so if you have access to the UI, it is a clear indication that you are using Flow mode.
I’m not sure where to go to check if I have access to this.
