I would like configure Grafana for Our Cassandra Cluster monitoring and planning to use Postgres as backend DB for Metrics Capture. Do anyone have any templates/tools I can use for this configuration to push metrics from My Cassandra node to Postgres DB?
Yea we want metrics to be stored in a DB Table not a text file.
If there is a way we can store Cassandra metrics in Same node we can go with the Plugin. Any suggestions on it pls?
Grafana Cassandra Plugin fetches the Metrics from a table right. How the Metrics can be stored in a table is the challenging part to us.
Will you help me with that please if any existing process available?
