How can I install the 4.6 version?
Hello all !
I’m very new on Grafana, and for a project which use currently Grafana 4.6, I have to install on a Debian a Grafana in 4.6.0.
So, I follow the instructions juste there : http://docs.grafana.org/v4.6/project/building_from_source/
but when I try to install the dependencies ( with :
yarn install --pure-lockfile
), I have a lot of errors , for example :
Error running install script for optional dependency: "/root/grafana/src/github.com/grafana/grafana/node_modules/iltorb: Command failed.
→ because the url of the .tar.gz of iltorb that yarn try to download doesn’t exist anymore…
and I have other code errors like : error: ‘class v8::Object’ has no member named ‘ForceSet’
I use npm v10.14.0 and node-gyp -v v3.6.2
My question is : is this a mistake of myself or we can’t install this version anymore ?
Thank you very much !
Léo
