i want to clone and build 4.4.3 version if i checkout and do sudo yarn install --pure-lockfile below error is shown
`[1/5] Validating package.json...
error grafana@4.4.3: The engine "node" is incompatible with this `
module. Expected version "4.x".
error Found incompatible module
info Visit https://yarnpkg.com/en/docs/cli/install for documentation `about this command.`
but in master and 4.5.x it works fine wondering what might be the problem
Thanks
Manju
