I am in Grafana Cloud and using Grafana Agent only. I am trying to have the least amount of infrastructure. -
I am trying to use a GEOMap panel and show what hosts are UP (green) and which ones are Down ( Red) or have issues ( Yellow ) -
I actually don’t know where to start, because if my host is down then I won’t have any data in grafana cloud , and if there is an issue with the host, that data is in grafana cloud.
So I think I need some sort of metric that is being derived from state that is currently only in grafana cloud.
Is this possible?
