janm
January 23, 2024, 7:56pm
1
i am using a home assitant helper to get daily consumption of my gas.
I try to get it via influxdb 2 in grafana.
My query looks like:
import "timezone"
option location = timezone.location(name: "Europe/Berlin")
from(bucket: "HomeAssistant")
|> filter(fn: (r) => r["friendly_name"] == "Gaszähler täglich")
|> filter(fn: (r) => r["_field"] == "value")
|> set(key: "_field", value: "VerbrauchHa2")
|> aggregateWindow(every: 24h, fn: max, createEmpty: false)
I have two problems:
i want to hide TODAY → I only want to have “full” days
The date displayed has an offset of one today to much.
I mean the last tag of the day before is mapped to the actual day.
grant2
January 27, 2024, 4:16pm
2
Hi @janm and welcome to the Grafana forum. Looks like you got off to a good start…
How about this?
import "timezone"
import "experimental/date/boundaries"
|> range(start: v.timeRangeStart, stop: boundaries.yesterday().stop)
I think you can use an offset in the aggregateWindow function. Something like the function shown below (you may need to play around with the + / - and value). I would also see if every: 1d vs. every: 24h makes a difference.
|> aggregateWindow(every: 1d, offset: -1d, fn: max, createEmpty: false)
Hello janm ,
I think you are using ViCare inegration, right?
I have the same issue regarding the one-day offset.
This must be related to the way ViCare reports consumption data just after midnight . Instead of resetting the values immediately to 0.0 m3 at 0:00 time, ViCare adds a new day and copies the consumption from the previous day.
After over half an hour the displayed values and bar graph are correct but it is well past midnight.
Perhaps the best way would be to read database values at 23:59 for each of the previous days? Is it possible in FLUX?
grant2
February 3, 2024, 2:29am
6
robertjot:
Yes, I think that timeshift would do this.
Thanks.
I will try to learn TIMESHIFT.
janm
February 27, 2024, 4:34pm
8
Thanks for your help @grant2 .
with yesterday in range it fixed double today for me.
now i have only the problem that the days are connected to wrong days
so i want to try timeshift . I think i only need 1 second or am I wrong in my mind:
import "timezone"
so
is in Homeassistant correct and “yesterday”
janm
February 27, 2024, 4:39pm
9
ok - after “playing” with the values i think i’ve found a solution:
import "timezone"
|> timeShift(duration: -1d)
