Hiding a row/panel
Hello!
i’m currently have a dashboard which shows info for different Openstack hosts.
Host choosing is made as a variable in templating.
I wanted to add a rabbitmq graphs to this dashboard, but faced a problem.
Rabbitmq is installed only on controllers, so when i choose a non-controller host, rabbitmq panels are still there and show no data points.
The question is - can i hide specific row on specific variable values?
I tried row repeat, but it doesn’t hide the row, only adds new if multiple values are checked
Even when value = None, the row is still there
This is not possible
will this functionality ever be implemented? Or maybe it was already implemented since july?
It’s very convenient to have a slightly different services/servers on one dashboard, but empty graphs frightens a customer
This will likely not be implemented
I was looking into this option as well and came across this post.
Is the idea still, after a couple of years, that this option won’t be available? It would help me a lot to get Grafana integrated in the company I work for.
There’s something of a workaround/alternative available, if you’re willing to dive into Javascript (a departure I know :grimacing: )
See here: Can I hide the panel based on a variable value on grafana Dashboard? - #3 by samjewell
also can be done with business chart plugin
