I’ve manage to use SNMP to pull information from my home access point. I want to create a small table that shows 2 columns and 1 row.
Version and Compiled
As you can see I have a Time column I can’t seem to remove and it showing multiple lines instead of 1. Is there a way I can pull out information from the description and put until a ‘Version’ and ‘Compiled’ column.
The SNMP walk only contains this info in the Description which is a lot of info and I just want to pull out some test within that.
