I am using a heatmap to plot all traffic that appeared on one intersection. I usually set map view -> initial view -> coordinates
to the coordinates of the intersection.
I changed my setup a bit, there are multiple intersections all in one city, so now my dashboard is using repeating variables to create a panel for each one. The absolute coordinates system doesn’t work anymore, and I want to switch to fit-to-data.
Fit-to-data does not zoom in to the intersection. Instead, it shows a single red blob in North America using the whole world as a map. I have to zoom in manually to see the details on the intersection. Please help me figure this out.
I have tried:
map view -> initial view ->fit-to-data ->data
using a specific layer, and last value. Both did not work -
going back to coordinates, and just trying to use variables instead of actual coordinates. Does not let me input the variable names, seems like coordinates need to be numbers.
funnily enough, when layer type is
markers
instead ofheatmap
, it zooms in to the intersection. So I don’t think it is a problem with my dataset.
