I’ve run into a problem, or maybe I don’t understand why it should be this way.
The Heatmap panel shows the blocks at the legend with the end time of the block instead of the start time. This makes no sense for me. Why would I ever want to know when the block ended instead of knowing when that block started?
Example on play.grafana.org
This block clearly started at 19:00:00 and ended at 19:15:00, why is it labelled as 19:15:00? It should be labelled 19:00:00, as that’s the start time of the block.
An option to use the start or end time would be appreciated
