Hello. Please help. I’ve installed grafana and inflixdb on Raspberry Pi 3b + all ok. In grafana I have setup the data source as influxdb saved and tested all ok. However on the grafana dashboard there is a line through install data source but no green tick… is this normal?
Thanks.
No, you are missing the icon font. In the instructions for installing the Debian Grafana package, it has an instruction for installing the libfontconfig1 package:
sudo apt-get install -y adduser libfontconfig1
Does that fix it?
Hello, thanks for your reply. Unfortunately it did not fix the problem.
