HI there.
I have grafana instance launched in docker container behind nginx proxy
docker run --restart=always -d --name=grafana -p 3000:3000 -v grafana-data:/var/lib/grafana grafana/grafana
Added to grafana.ini accroding to the article next values (domain particularly):
[server]
# Protocol (http, https, h2, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = grafana.mycompany.com
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = %(protocol)s://%(domain)s:%(http_port)s/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = false
# Log web requests
;router_logging = false
# the path relative working path
;static_root_path = public
# enable gzip
;enable_gzip = false
# https certs & key file
;cert_file =§
;cert_key =
# Unix socket path
;socket =
Set up nginx reverse proxy:
server {
listen 80;
server_name grafana.mycompany.com;
location / {
return 301 https://$server_name$request_uri;
server {
listen 443;
proxy_read_timeout 3600s;
large_client_header_buffers 16 32k;
ssl on;
ssl_certificate /etc/nginx/conf.d/ssl/grafana.crt;
ssl_certificate_key /etc/nginx/conf.d/ssl/grafana.key;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/grafana.access.log;
location / {
client_max_body_size 100M;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_send_timeout 600s;
proxy_read_timeout 600s;
#proxy_redirect off;
proxy_pass http://grafana.staged-by-discourse.com;
server {
listen 443;
server_name grafana;
return 301 https://$server_name.mycompany.com$request_uri;
Interface is shown but graphs are not loaded (see screenshot)
)Logs show no errors when I requested data:
t=2020-10-19T17:15:17+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/api/v1/query_range status=301 remote_addr=xxxxxxtime_ms=1 size=185 referer="https://grafana.mycompany.com/d/_NNAgsPZk/teamcity-cloud-agents?orgId=1"
t=2020-10-19T17:15:17+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/api/v1/query_range status=301 remote_addr=xxxxx time_ms=2 size=185 referer="https://grafana.mycompany.com/d/_NNAgsPZk/teamcity-cloud-agents?orgId=1"
t=2020-10-19T17:15:17+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/api/v1/query_range status=301 remote_addr=xxxxxxx time_ms=1 size=185 referer="https://grafana.mycompany.com/d/_NNAgsPZk/teamcity-cloud-agents?orgId=1"
t=2020-10-19T17:15:17+0000 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/api/v1/query_range status=301 remote_addr=xxxxxx time_ms=2 size=185 referer="https://grafana.mycompany.com/d/_NNAgsPZk/teamcity-cloud-agents?orgId=1"
Though http works fine.
Stuck on this. Any idea what this issue is about ?
Thanks in advance
