i somehow have the issue that i cannot access grafana webinterface through nginx reverse proxy and neither directly.
Strange is, it does work in a browser where i initially had set up grafana, there is a session cookie “grafana_session”, when i copy this cookie to a browser where it does not work, it works.
– Current docker image (grafana/grafana:latest)
– Docker Compose:
grafana-1:
container_name: grafana-1
hostname: grafana-1
image: grafana/grafana:latest
restart: unless-stopped
networks:
- grafana_internal
ports:
- "3000:3000"
- "9094:9094"
volumes:
- "/mnt/data/grafana/grafana.ini:/etc/grafana/grafana.ini:ro"
- "/mnt/data/grafana/ldap-domain.toml:/etc/grafana/ldap-domain.toml:ro"
- "/mnt/data/grafana/plugins:/var/lib/grafana/plugins"
environment:
GF_LOG_LEVEL: debug
– Connect through nginx / connect directly to [IP-Address:3000] -
What happened?
– Switched to another browser -
– GUI to load -
– Currently “domain”,“enforce_domain”, “root_url” are disabled for testing without reverse proxy
app_mode = production
instance_name = ${HOSTNAME}
[server]
enable_gzip = true
protocol = http
http_port = 3000
;domain = grafana.domain.local
;enforce_domain = true
;root_url = https://grafana.domain.local/
router_logging = true
[database]
type = postgres
host = grafana-db:5432
name = grafana
user = grafana
password = password
ssl_mode = disable
[analytics]
reporting_enabled = false
enable_feedback_links = false
[security]
admin_user = grafadmin
admin_email = grafana@domain.com
cookie_secure = false
disable_gravatar = true
[users]
allow_sign_up = true
allow_org_create = false
default_theme = light
hidden_users = grafadmin
login_hint = e-mail or upn
[auth.basic]
enabled = true
[smtp]
enabled = true
host = smtp.domain.local:25
skip_verify = true
from_address = grafana@domain.com
from_name = Grafana
ehlo_identity = grafana.domain.local
startTLS_policy = NoStartTLS
[auth.ldap]
enabled = true
config_file = /etc/grafana/ldap-domain.toml
skip_org_role_sync = false
[unified_alerting]
enabled = true
ha_peers = grafana-1:9094, grafana-2:9094
[help]
enabled = false
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
– No error logs - i enabled debug and routing logs and i only get this every time i try to access the page
logger=infra.kvstore.sql t=2022-11-15T16:26:08.549870228Z level=debug msg="kvstore value not found" orgId=0 namespace=serviceaccounts key=hideApiKeys
logger=context userId=0 orgId=0 uname= t=2022-11-15T16:26:08.55345748Z level=info msg="Request Completed" method=GET path=/login status=200 remote_addr=172.16.40.167 time_ms=7 duration=7.433125ms size=6004 referer= handler=/login
