I’m using graphite/go-carbon and grafana.
I search a way to create a tree view which contains all performance metrics and create a tree view contains only configuration for elements.
Actually, i have to copy a second time some .wsp file in an other configuration tree to create dashboard. So each performance import take a lot of disk space…
an example:
performance tree view:
metrics.model.serial.volumes.volume1{read_io,write_io,read_response,write_response}
metrics.model.serial.volumes.volume2{read_io,write_io,read_response,write_response}
metrics.model.serial.volumes.volume3{read_io,write_io,read_response,write_response}
etc…
for server tree view:
metrics.model.serial.server1.volume1{read_io,write_io,read_response,write_response}
metrics.model.serial.server1.volume2{read_io,write_io,read_response,write_response}
metrics.model.serial.server2.volume1{read_io,write_io,read_response,write_response}
metrics.model.serial.server2.volume3{read_io,write_io,read_response,write_response}
etc…
I create dashboard specially for server or for volumes, etc…
Is exist a way to search metrics from an other folder, like to search in a other table with sql?
Many thanks for help
