is it possible in grafana to have a library of queries? we use the same query on several different dashboards, and when the parameters of said query change we need to update the query on all the dashboards. a simple library of query text would be handy so that we would only have to change the query once. it is possible to share panel result sets, but this is slightly different. a) it’s across dashboard, and b) i want to be able to stack a bunch of saved queries into a graph, not just the results of one panel.
Related topics
| Topic | Replies | Views | Activity | |
| Does Grafana queries output and data points can we store back to graphite or any other databases | 0 | 177 | July 24, 2023 | |
| Grafana API to search for dashboards that are using a specific datasource | 1 | 819 | April 5, 2023 | |
| API references which queries data from Data Source | 0 | 306 | July 9, 2021 | |
| Grafana Jaeger - Plot multiple queries | 0 | 293 | February 14, 2023 | |
| How to get the panel query or queries from the api | 5 | 5030 | November 16, 2022 |
