Graphana misleading data representation
Hi, i got unsolved mistery that i can’t understand.
Our data is in a PostgreSQL database. This graph is using log table of our completed crawler (it can be either completed, failed, timedout or died).
For the exemple below, the inteval is 10min for a timefilter of the last 7 days
Graphana render the only fail of the day, over full day like if they were many failed in a row.
    Unsure, don’t know where to find the graphana version. Pop’OS
    Rendering a graph showing the the percentage of success of our process.
SELECT
$__timeGroupAlias(crawler."timestamp",$__interval,0),
  COUNT(CASE WHEN status='DIED' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status  ~ '(COMPLETED|FAILED|DIED|TIMEDOUT).*' THEN 1 END)::float),0)*100 as "%DIED",
  COUNT(CASE WHEN status='FAILED' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status  ~ '(COMPLETED|FAILED|DIED|TIMEDOUT).*' THEN 1 END)::float),0)*100 as "%FAILED",
  COUNT(CASE WHEN status='TIMEDOUT' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status  ~ '(COMPLETED|FAILED|DIED|TIMEDOUT).*'  THEN 1 END)::float),0)*100 as "%TIMEDOUT",
  COUNT(CASE WHEN status='COMPLETED' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status  ~ '(COMPLETED|FAILED|DIED|TIMEDOUT).*'  THEN 1 END)::float),0)*100 as "%COMPLETED"
FROM crawler
LEFT JOIN biz on biz.id = biz_id
LEFT JOIN application ON crawler.application_id = application.id
LEFT JOIN vendor ON application.vendor_id = vendor.id
WHERE
  $__timeFilter(crawler.timestamp) AND NOT biz.module IN('Pending') AND vendor.name IN($vendor_name) AND biz.name IN($biz_name)
GROUP BY 1
  "id": 23763571993,
  "gridPos": {
    "h": 9,
    "w": 6,
    "x": 0,
    "y": 1
  "type": "timeseries",
  "title": "${biz_name} - Crawler result",
  "scopedVars": {
    "biz_name": {
      "text": "Blurred",
      "value": "Blurred",
      "selected": false
  "repeat": "biz_name",
  "repeatDirection": "h",
  "maxPerRow": 4,
  "fieldConfig": {
    "defaults": {
      "custom": {
        "drawStyle": "bars",
        "lineInterpolation": "linear",
        "barAlignment": 0,
        "lineWidth": 0,
        "fillOpacity": 84,
        "gradientMode": "none",
        "spanNulls": false,
        "showPoints": "auto",
        "pointSize": 5,
        "stacking": {
          "mode": "normal",
          "group": "A"
        "axisPlacement": "auto",
        "axisLabel": "",
        "scaleDistribution": {
          "type": "linear"
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
        "thresholdsStyle": {
          "mode": "off"
      "color": {
        "mode": "palette-classic"
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "color": "green",
            "value": null
            "color": "red",
            "value": 80
      "mappings": [],
      "max": 100
    "overrides": [
        "matcher": {
          "id": "byName",
          "options": "%COMPLETED"
        "properties": [
            "id": "color",
            "value": {
              "fixedColor": "dark-green",
              "mode": "fixed"
        "matcher": {
          "id": "byName",
          "options": "%TIMEDOUT"
        "properties": [
            "id": "color",
            "value": {
              "fixedColor": "dark-orange",
              "mode": "fixed"
        "matcher": {
          "id": "byName",
          "options": "%FAILED"
        "properties": [
            "id": "color",
            "value": {
              "fixedColor": "dark-yellow",
              "mode": "fixed"
        "matcher": {
          "id": "byName",
          "options": "%DIED"
        "properties": [
            "id": "color",
            "value": {
              "fixedColor": "dark-purple",
              "mode": "fixed"
  "options": {
    "tooltip": {
      "mode": "single"
    "legend": {
      "displayMode": "list",
      "placement": "bottom",
      "calcs": []
  "targets": [
      "format": "time_series",
      "group": [],
      "metricColumn": "none",
      "rawQuery": true,
      "rawSql": " SELECT\n  $__timeGroupAlias(crawler.\"timestamp\",$__interval,0),\n  COUNT(CASE WHEN status='DIED' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status IN ('COMPLETED','FAILED','DIED','TIMEDOUT') THEN 1 END)::float),0)*100 as \"%DIED\",\n  COUNT(CASE WHEN status='FAILED' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status IN ('COMPLETED','FAILED','DIED','TIMEDOUT') THEN 1 END)::float),0)*100 as \"%FAILED\",\n  COUNT(CASE WHEN status='TIMEDOUT' THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status IN ('COMPLETED','FAILED','DIED','TIMEDOUT') THEN 1 END)::float),0)*100 as \"%TIMEDOUT\",\n  COUNT(CASE WHEN status IN('COMPLETED') THEN 1 END)::float/NULLIF((COUNT(CASE WHEN status IN ('COMPLETED','FAILED','DIED','TIMEDOUT') THEN 1 END)::float),0)*100 as \"%COMPLETED\"\nFROM crawler\n  LEFT JOIN biz on biz.id = biz_id\n  LEFT JOIN application ON crawler.application_id = application.id\n  LEFT JOIN vendor ON application.vendor_id = vendor.id\nWHERE\n    $__timeFilter(crawler.timestamp) AND NOT biz.module IN('Pending') AND vendor.name IN($vendor_name) AND biz.name IN($biz_name)\nGROUP BY 1\n\n",
      "refId": "A",
      "select": [
            "params": [
              "value"
            "type": "column"
      "timeColumn": "time",
      "where": [
          "name": "$__timeFilter",
          "params": [],
          "type": "macro"
  "transparent": true,
  "description": "",
  "datasource": null
Thanks for the help
