hi
datasource is : mysql
my query sql is : SELECT UNIX_TIMESTAMP(T.createdate) as time_sec,T.type_value as VALUE,T.col_type as metric FROM mytest T WHERE T.col_type = ‘A’
query result is :
bug grafana view is :
how can i do that let graph display
hi
query result is :
try returning a value column (lowercase). Also make sure the time points are within the dashboard time range (and include a $__timeFilter macro)
Thank you very much for your answer
