6.5.3. -
Example, I want to get the number of servers which have a CPU utilization of over 90%, in a single host group. I tried to use the “removeBelowValue” function to remove values under 90%, and then used the count function to get the count, but the “removeBelowValue” doesn’t actually remove/filter values, it just changes them to “null”. So doing a “count” function is not accurate/does nothing since the results under 90% never get filtered.
The only “filter” functions I see that actually remove values are “bottom/top”, but in my case, I want a “count”, instead of top xx values or bottom xx values.
What happened?
