Grafana with https - Cannot find SSL cert_file
I’m running Grafana in a Docker container on my NAS. Everything is fine when using http. However I fail to start the container when I setup Grafana for https, as the Certificate file can’t be found according to the Docker log.
I create a self-certificate using OpenSSL in order to use Grafana with https. I modified the docker script to overwrite the enviroment Server section for https and defined the path for the cert and key file.
  INFO[12-08|12:28:50] Config overridden from Environment variable logger=settings var="GF_SERVER_PROTOCOL=https"
  INFO[12-08|12:28:50] Config overridden from Environment variable logger=settings var="GF_SERVER_CERT_FILE=/share/CACHEDEV2_DATA/Container/grafana/config/ssl/grafana.crt"
  INFO[12-08|12:28:50] Config overridden from Environment variable logger=settings var="GF_SERVER_CERT_KEY=/share/CACHEDEV2_DATA/Container/grafana/config/ssl/grafana.key"
As far as I can see, this seems to be fine, however for unknown reason the cert-file isn’t found, even it is available in the defined path.
INFO[12-08|12:28:50] HTTP Server Listen                       logger=http.server address=0.0.0.0:3000 protocol=https subUrl= socket=
EROR[12-08|12:28:50] Stopped HTTPServer                       logger=server reason="Cannot find SSL cert_file at /share/CACHEDEV2_DATA/Container/grafana/config/ssl/grafana.crt"
When I check the path I see it is valid
[/share/CACHEDEV2_DATA/Container/grafana] # ls -l /share/CACHEDEV2_DATA/Container/grafana/config/ssl/grafana.crt
-rw-r--r-- 1 admin administrators 1228 2019-12-08 10:55 /share/CACHEDEV2_DATA/Container/grafana/config/ssl/grafana.crt
Any idea what could be the reason for this? Could the Certificate be invalid and the error message is just misleading?
Many thanks for a hint :slight_smile:
Stefan
It’s have been a while since you asked but if for some reason someone get to this post the matter is the certs file paths. You need to place the certs files somewhere the inner container user can access to it for example: /etc/ssl. I previously copied the letsencrypt certs into a /certs folder inside letsencrypt grafana site directory
  grafana:
    image: grafana/grafana
    container_name: grafana
    environment:
      GF_SECURITY_ADMIN_USER: ${GRAFANA_USER}
      GF_SECURITY_ADMIN_PASSWORD: ${GRAFANA_PASSWORD}
      GF_SERVER_HTTP_PORT: 443
      GF_SERVER_PROTOCOL: https
      GF_SERVER_ROOT_URL: https://grafana.mydomain.com/
      GF_SERVER_CERT_FILE: /etc/ssl/grafana.crt
      GF_SERVER_CERT_KEY: /etc/ssl/grafana.key
    user: '0'
    ports:
      - "443:443"
    volumes:
      - grafana_data:/var/lib/grafana
      - /etc/letsencrypt/live/grafana.mydomain.com/certs:/etc/ssl
    restart: unless-stopped
    networks:
      - mynetwork
It’s important that yo specify user: ‘0’ cause grafana user has no permission to access /etc/ssl
Yeah, but you just sacrified some security. You made container where app is running under root (user id 0), fromby default secure rootless container. Make sure you understand the consequences and accept risk from this change. I wouldn’t recommended it generally.
