Grafana with GrayLog as datasource?
We are using GrayLog in front of an ElasticSearch cluster, and we don’t have access to the ElasticSearch cluster directly because GrayLog does all the authorization/filtering based on ACL, etc…
Is it possible to use GrayLog API as datasource for Grafana ? Is there a plugin for that ?
Thanks
No, Grafana can only speak directly to Elasticsearch, so unless Graylog has a way to go directly to an HTTP api that is Elasticsearch
If you want commercial support for developing such plugins feel free to contact us. https://grafana.com/services/support/
Thank you for your answer, it confirms what I thought.
