hi,
we have the lates Grafana version and Graylog 3.0.2. My goal was to add a (ELK) datasource for creating graphs from our Fortigate logs and blocks. What ever I try, it fails and I get a 404. Our Graylog ULR is https://graylog.example.com/ (no port) and we have authentication enabled. Also I tried to play with the index (graylog_* / graylog_0 … etc) … but no success. I have only a 404.
If I test the source:
192.168.x.x - - [06/Jan/2020:09:50:34 +0100] "GET /graylog_%2A/_mapping HTTP/1.1" 200 455 "-" Grafana/6.5.2"
The "%2A comes from the Index grafana_*.
Our graylog is behind a Apache2 reverse proxy https://graylog.example.com/ which forwards everything to the internal Graylog host and port.
If I try to use the ELK datasource:
192.168.x.x - - [06/Jan/2020:09:53:14 +0100] "POST /_msearch HTTP/1.1" 404 50 "-" "Grafana/6.5.2"
which results in a 404.
Question is: How can I get the streams / logs into my Grafana Dashboard
Any suggestions ?
