Grafana viewer to see logs from graylog tha use elasticsearch and mongodb
    grafana 8.5.21 DEBIAN11 BULLEYE
    I am trying to conecto with another machine to see logs with graylog tha use mongoDB and elasticsearch
  • How are you trying to achieve it? I am only try to see the logs to make dashboards.
  • What happened?
    I can´t connect to Elasticsearch or mongodb
  • What did you expect to happen? I expect connect to elasticsearch or mongodb.
    The configuration is the standard.
    I cant connect with elasticsearch or mongodb.
    NO.
My question is , have I install the grafana server in the same machine that graylog to connect elasticsearch or mongodb?
Best regards.
