Hi, using webhook to send alerts to specific endpoint on webhook.
Grafana version - grafana-4.6.3-1.x86_64
Configured webhook Channel (unable to test as there is no way to send message with this and it throws error code 400 due to blanl message)
Configured alert with notification where I have message field updated with some texts.
Getting below error while sending alerts to webhook but same works for mail.
msg=“Webhook failed” logger=notifications.webhook statuscode=“400 Bad Request” body="{"message":"Both text and markdown cannot be empty in the same request.","errors":[{"description":"Both text and markdown cannot be empty in the same request."}],
- My webhook works fine on command line using curl with some text
