Grafana not sending anything in body of webhook message
HI,
I’ve finally got my system alerting using webhooks but there’s nothing being sent in the body of the message. According to the docs, and post @ Grafana Webhook, there should be a JSON string being sent but on examination of the request object the body contains nothing:
body: {},
We’re using Garfana 4.6 - would an upgrade to 5.3 help?
TIA
Martin
Anybody using Webhooks and come across the same problem? For that matter anyone using Webhooks and get info in the body? Need to get some info as it’s holding me up. I’m using Webhooks to call an endpoint that’ll allow me to run scripts and sound alarms (as there’s no way of doing that!!)
TIA
Well, upgrading to 5.2.4 hasn’t helped. This is the message I get:
IncomingMessage {
_readableState:
ReadableState {
objectMode: false,
highWaterMark: 16384,
buffer: BufferList { head: null, tail: null, length: 0 },
length: 0,
pipes: null,
pipesCount: 0,
flowing: null,
ended: false,
endEmitted: false,
reading: false,
sync: true,
needReadable: false,
emittedReadable: false,
readableListening: false,Preformatted text
resumeScheduled: false,
destroyed: false,
defaultEncoding: ‘utf8’,
awaitDrain: 0,
readingMore: true,
decoder: null,
encoding: null },
readable: true,
domain: null,
_events: {},
_eventsCount: 0,
_maxListeners: undefined,
socket:
Socket {
connecting: false,
_hadError: false,
_handle:
TCP {
reading: true,
owner: [Circular],
onread: [Function: onread],
onconnection: null,
writeQueueSize: 0,
_consumed: true },
_parent: null,
_host: null,
_readableState:
ReadableState {
objectMode: false,
buffer: [Object],
length: 0,
pipes: null,
pipesCount: 0,
flowing: true,
ended: false,
endEmitted: false,
reading: true,
sync: false,
needReadable: true,
destroyed: false,
awaitDrain: 0,
readingMore: false,
decoder: null,
encoding: null },
readable: true,
domain: null,
_events:
{ end: [Array],
_socketEnd: [Function: onSocketEnd],
drain: [Array],
timeout: [Function: socketOnTimeout],
data: [Function: bound socketOnData],
error: [Function: socketOnError],
close: [Array],
resume: [Function: onSocketResume],
pause: [Function: onSocketPause] },
_eventsCount: 9,
_writableState:
WritableState {
objectMode: false,
finalCalled: false,
needDrain: false,
ending: false,
ended: false,
finished: false,
destroyed: false,
decodeStrings: false,
length: 0,
writing: false,
corked: 0,
sync: true,
bufferProcessing: false,
onwrite: [Function: bound onwrite],
writecb: null,
writelen: 0,
bufferedRequest: null,
lastBufferedRequest: null,
pendingcb: 0,
prefinished: false,
errorEmitted: false,
bufferedRequestCount: 0,
corkedRequestsFree: [Object] },
writable: true,
allowHalfOpen: true,
_bytesDispatched: 0,
_sockname: null,
_pendingData: null,
_pendingEncoding: ‘’,
server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_usingSlaves: false,
_slaves: [],
_unref: false,
pauseOnConnect: false,
httpAllowHalfOpen: false,
timeout: 120000,
keepAliveTimeout: 5000,
_pendingResponseData: 0,
maxHeadersCount: null,
_connectionKey: ‘6::::4000’,
[Symbol(IncomingMessage)]: [Object],
[Symbol(ServerResponse)]: [Object],
[Symbol(asyncId)]: 5 },
_server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_slaves: [],
_unref: false,
timeout: 120000,
_idleTimeout: 120000,
_idleNext:
TimersList {
_idleNext: [Circular],
_idlePrev: [Circular],
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idlePrev:
TimersList {
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idleStart: 318739,
_destroyed: false,
parser:
HTTPParser {
‘0’: [Function: parserOnHeaders],
‘1’: [Function: parserOnHeadersComplete],
‘2’: [Function: parserOnBody],
‘3’: [Function: parserOnMessageComplete],
‘4’: [Function: bound onParserExecute],
_headers: [],
_url: ‘’,
_consumed: true,
socket: [Circular],
incoming: [Circular],
outgoing: null,
maxHeaderPairs: 2000,
onIncoming: [Function: bound parserOnIncoming] },
on: [Function: socketOnWrap],
_paused: false,
_httpMessage:
ServerResponse {
domain: null,
_events: [Object],
_eventsCount: 1,
output: [],
outputEncodings: [],
outputCallbacks: [],
outputSize: 0,
writable: true,
_last: false,
upgrading: false,
chunkedEncoding: false,
shouldKeepAlive: true,
useChunkedEncodingByDefault: true,
sendDate: true,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
_contentLength: null,
_hasBody: true,
_trailer: ‘’,
finished: false,
_headerSent: false,
socket: [Circular],
connection: [Circular],
_header: null,
_onPendingData: [Function: bound updateOutgoingData],
_sent100: false,
_expect_continue: false,
req: [Circular],
locals: {},
[Symbol(outHeadersKey)]: [Object] },
[Symbol(asyncId)]: 23,
[Symbol(bytesRead)]: 0,
[Symbol(asyncId)]: 25,
[Symbol(triggerAsyncId)]: 23 },
connection:
Socket {
connecting: false,
_hadError: false,
_handle:
TCP {
reading: true,
owner: [Circular],
onconnection: null,
writeQueueSize: 0,
_consumed: true },
_parent: null,
_host: null,
_readableState:
ReadableState {
objectMode: false,
buffer: [Object],
length: 0,
pipes: null,
pipesCount: 0,
flowing: true,
ended: false,
endEmitted: false,
reading: true,
sync: false,
needReadable: true,
destroyed: false,
awaitDrain: 0,
readingMore: false,
decoder: null,
encoding: null },
readable: true,
domain: null,
_events:
{ end: [Array],
drain: [Array],
close: [Array],
_eventsCount: 9,
_writableState:
WritableState {
objectMode: false,
finalCalled: false,
needDrain: false,
ending: false,
ended: false,
finished: false,
destroyed: false,
length: 0,
writing: false,
corked: 0,
sync: true,
writecb: null,
writelen: 0,
pendingcb: 0,
prefinished: false,
writable: true,
_sockname: null,
_pendingData: null,
server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_slaves: [],
_unref: false,
timeout: 120000,
_server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_slaves: [],
_unref: false,
timeout: 120000,
_idleNext:
TimersList {
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idlePrev:
TimersList {
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idleStart: 318739,
_destroyed: false,
parser:
HTTPParser {
_headers: [],
_url: ‘’,
_consumed: true,
socket: [Circular],
outgoing: null,
_paused: false,
_httpMessage:
ServerResponse {
domain: null,
_events: [Object],
_eventsCount: 1,
output: [],
outputSize: 0,
writable: true,
_last: false,
upgrading: false,
sendDate: true,
_removedTE: false,
_hasBody: true,
_trailer: ‘’,
finished: false,
_headerSent: false,
socket: [Circular],
_header: null,
_sent100: false,
req: [Circular],
locals: {},
httpVersionMajor: 1,
httpVersionMinor: 1,
httpVersion: ‘1.1’,
complete: false,
headers:
{ host: ‘localhost:4000’,
‘user-agent’: ‘Grafana’,
‘content-length’: ‘239’,
‘content-type’: ‘application/json’,
‘accept-encoding’: ‘gzip’ },
rawHeaders:
[ ‘Host’,
‘localhost:4000’,
‘User-Agent’,
‘Grafana’,
‘Content-Length’,
‘239’,
‘Content-Type’,
‘application/json’,
‘Accept-Encoding’,
‘gzip’ ],
trailers: {},
rawTrailers: [],
upgrade: false,
url: ‘/GrafanaWebhook’,
method: ‘POST’,
statusCode: null,
statusMessage: null,
client:
Socket {
connecting: false,
_hadError: false,
_handle:
TCP {
reading: true,
owner: [Circular],
onconnection: null,
writeQueueSize: 0,
_consumed: true },
_parent: null,
_host: null,
_readableState:
ReadableState {
objectMode: false,
buffer: [Object],
length: 0,
pipes: null,
pipesCount: 0,
flowing: true,
ended: false,
endEmitted: false,
reading: true,
sync: false,
needReadable: true,
destroyed: false,
awaitDrain: 0,
readingMore: false,
decoder: null,
encoding: null },
readable: true,
domain: null,
_events:
{ end: [Array],
drain: [Array],
close: [Array],
_eventsCount: 9,
_writableState:
WritableState {
objectMode: false,
finalCalled: false,
needDrain: false,
ending: false,
ended: false,
finished: false,
destroyed: false,
length: 0,
writing: false,
corked: 0,
sync: true,
writecb: null,
writelen: 0,
pendingcb: 0,
prefinished: false,
writable: true,
_sockname: null,
_pendingData: null,
server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_slaves: [],
_unref: false,
timeout: 120000,
_server:
Server {
domain: null,
_events: [Object],
_eventsCount: 2,
_connections: 1,
_handle: [Object],
_slaves: [],
_unref: false,
timeout: 120000,
_idleNext:
TimersList {
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idlePrev:
TimersList {
_timer: [Object],
_unrefed: true,
msecs: 120000,
nextTick: false },
_idleStart: 318739,
_destroyed: false,
parser:
HTTPParser {
_headers: [],
_url: ‘’,
_consumed: true,
socket: [Circular],
outgoing: null,
_paused: false,
_httpMessage:
ServerResponse {
domain: null,
_events: [Object],
_eventsCount: 1,
output: [],
outputSize: 0,
writable: true,
_last: false,
upgrading: false,
sendDate: true,
_removedTE: false,
_hasBody: true,
_trailer: ‘’,
finished: false,
_headerSent: false,
socket: [Circular],
_header: null,
_sent100: false,
req: [Circular],
locals: {},
_consuming: false,
_dumped: false,
next: [Function: next],
baseUrl: ‘’,
originalUrl: ‘/GrafanaWebhook’,
_parsedUrl:
Url {
protocol: null,
slashes: null,
auth: null,
host: null,
port: null,
hostname: null,
hash: null,
search: null,
query: null,
pathname: ‘/GrafanaWebhook’,
path: ‘/GrafanaWebhook’,
href: ‘/GrafanaWebhook’,
_raw: ‘/GrafanaWebhook’ },
params: {},
query: {},
res:
ServerResponse {
domain: null,
_events: { finish: [Function: bound resOnFinish] },
_eventsCount: 1,
output: [],
outputSize: 0,
writable: true,
_last: false,
upgrading: false,
sendDate: true,
_removedTE: false,
_hasBody: true,
_trailer: ‘’,
finished: false,
_headerSent: false,
socket:
Socket {
connecting: false,
_hadError: false,
_handle: [Object],
_parent: null,
_host: null,
_readableState: [Object],
readable: true,
domain: null,
_events: [Object],
_eventsCount: 9,
_writableState: [Object],
writable: true,
_sockname: null,
_pendingData: null,
server: [Object],
_server: [Object],
_idleNext: [Object],
_idlePrev: [Object],
_idleStart: 318739,
_destroyed: false,
parser: [Object],
_paused: false,
_httpMessage: [Circular],
connection:
Socket {
connecting: false,
_hadError: false,
_handle: [Object],
_parent: null,
_host: null,
readable: true,
domain: null,
_events: [Object],
_eventsCount: 9,
writable: true,
_sockname: null,
_pendingData: null,
server: [Object],
_server: [Object],
_idleStart: 318739,
_destroyed: false,
parser: [Object],
_paused: false,
_header: null,
_sent100: false,
req: [Circular],
locals: {},
[Symbol(outHeadersKey)]: { ‘x-powered-by’: [Array] } },
body: {},
route:
Route {
stack: [ [Object] ],
methods: { post: true } } }
which shows, on almost the last line, that there nothing/nada/zilch in the body.
