grafana-8.1.2
Linux -
Configure webhook to get alerts. -
Following the steps here -
What happened?
The notification doesnt work, see the following error in the logs
t=2022-01-06T20:14:25+0000 lvl=eror msg="Failed to send webhook" logger=alerting.notifier.webhook error="Webhook response status 405 Not Allowed" webhook="Alert to Tenant-amit"
t=2022-01-06T20:14:25+0000 lvl=eror msg="failed to send notification" logger=alerting.notifier uid= error="Webhook response status 405 Not Allowed"
t=2022-01-06T20:14:25+0000 lvl=eror msg="Failed to send alert notifications" logger=context userId=1 orgId=1 uname=admin error="Webhook response status 405 Not Allowed" remote_addr=10.0.3.252
t=2022-01-06T20:14:25+0000 lvl=eror msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=POST path=/api/alert-notifications/test status=500 remote_addr=10.0.3.252 time_ms=40 size=48 referer=http://a403e60d0765b4239aae11b337538dcf-2014184081.us-west-2.elb.amazonaws.com/alerting/notification/1/edit
My endpoint should receive the alert. -
"id": 1,
"uid": "ZaJVLw0nz",
"name": "Alert to Tenant-amit",
"type": "webhook",
"isDefault": false,
"sendReminder": false,
"disableResolveMessage": false,
"frequency": "",
"created": "2022-01-06T05:14:16Z",
"updated": "2022-01-06T20:33:38Z",
"settings": {
"addresses": "",
"autoResolve": true,
"httpMethod": "POST",
"password": "",
"severity": "critical",
"uploadImage": false,
"url": "https://tenant-amit.dev.unskript.io/internal/events/sns/eyJlbnZpcm9ubWVudF9pZCI6ImY1NmUzY2ZkLTMwNjctNGZiYy1iYzc5LWEyNWM1YTUyZmYwNCIsImNvbm5lY3Rvcl9pZCI6IjQzOTZiNjJlLWExOGEtNGJjZi1hNWYyLWM2NWZjZGUwNjIyZSJ9",
"username": ""
"secureFields": {}
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
https://grafana.com/docs/grafana/latest/alerting/old-alerting/notifications/#webhook
