Grafana vs Wrike API
Hi everyone,
I’m trying to set up a panel with a list of tasks from Wrike API.
I’m just create a datasource and message says “Data source is working” but when I try to fetch the results in a panel the panel inspect, in data tab, says “no Data”.
If I click refresh button, in query tab, stuck in Loading query inspector.
The call to the API works smooth called via CURL
Why? What am I doing wrong?
Hello :wave: and welcome to the forum, @carmelito80
Can you please share the exact datasource plugin that you are using? It sounds like you are using of the JSON datasource plugins, but it would help if we knew exactly which one.
And can you share the exact JSON that your cURL command returns? That way someone in the community could also try and mock this up for you :+1:
