API - Fetch Data from Datasource/Dashboard created on Grafana using API
Hi there,
im a newbie to grafana. Really appreciate if someone can help me find how i can extract data from the datasources or dashboards i have created using api using python. Im successfully to establish connections to grafana and awas able to get details of datasources i created, but i’m not able to get their respective data.
Really appreciate your help here.
Thanks
Suprabhat/CMD
I have a similar problem. Hmmm… not the same. Didn’t use API.
See here: "Datasource Updated", "Database Connection OK" but "No Data"
