Plugin to fetch data from API
Hi, I am new to grafana and i would like to develop a plugin to fetch cost related data using AWS cost explorer endpoint api. Requests (Queries) have to be made to this API in json format. How can i build a plugin to do this? Really appreciate your help here.
Thanks. :slight_smile:
I would suggest to checkout the simple datasource plugin tutorial.
I’m also new to grafana, typescript and react, but i made it to fetch from a corona data platform numbers in json format.
Hi Mudu, did you send a json request (query) to fetch the data ?
Yeah I configured a field for the data source for the city and used that option in a params object to get json data
async doRequest(query: MyQuery) {
const { where } = query;
const result = await getBackendSrv().datasourceRequest({
method: β€˜GET’,
url: someurl as string,
params: {
where: where,
outFields: β€˜*’,
outSR: β€˜4326’,
f: β€˜json’,
return result;
