Grafana version compatibility check with Postgres SQL 18 Database
Can Grafana version 13.0.1 be compatible with Postgres SQL Database 18? Is there any matrix available?
Hello @avantikaroy Welcome to grafana community
Yes Grafana’s current documentation says Grafana supports PostgreSQL 12+ as its database backend. PostgreSQL 18 therefore falls within the documented supported range.
