Is Grafana compatible with newer versions of Postgres, such as version 17?
Has anyone tried to use Grafana with Postgres version 17? I end up using the latest available versions and if Grafana doesn’t keep up, then maybe I need to look for another solution.
I am not able to connect to my database.
Hi, on my side I’m using Postgres V17 and everything seems fine, I didn’t encounter compatibility issues until now.
