Grafana v13, title of first repeating row larger than following rows
  • What Grafana version and what operating system are you using? v13.3.0
  • What are you trying to achieve? implementing repeating rows
  • How are you trying to achieve it? through GUI, building froms cratch
  • What happened? all works as expected, data is shoing but the styling of the title of the first row is
  • What did you expect to happen? Titles styled the same
    "apiVersion": "dashboard.grafana.app/v2",
    "kind": "Dashboard",
    "metadata": {
    "name": "jep6tfg"
    "spec": {
    "annotations": [
    "kind": "AnnotationQuery",
    "spec": {
    "builtIn": true,
    "enable": true,
    "hide": true,
    "iconColor": "rgba(0, 211, 255, 1)",
    "name": "Annotations & Alerts",
    "query": {
    "datasource": {
    "name": "-- Grafana --"
    "group": "grafana",
    "kind": "DataQuery",
    "spec": {},
    "version": "v0"
    "cursorSync": "Off",
    "editable": true,
    "elements": {
    "panel-1": {
    "kind": "Panel",
    "spec": {
    "data": {
    "kind": "QueryGroup",
    "spec": {
    "queries": [
    "kind": "PanelQuery",
    "spec": {
    "hidden": false,
    "query": {
    "group": "",
    "spec": {},
    "version": "v0"
    "refId": "A"
    "queryOptions": {},
    "transformations":
    "description": "",
    "id": 1,
    "links": ,
    "title": "New panel",
    "vizConfig": {
    "group": "timeseries",
    "kind": "VizConfig",
    "spec": {
    "fieldConfig": {
    "defaults": {
    "color": {
    "mode": "palette-classic"
    "custom": {
    "axisBorderShow": false,
    "axisCenteredZero": false,
    "axisColorMode": "text",
    "axisLabel": "",
    "axisPlacement": "auto",
    "barAlignment": 0,
    "barWidthFactor": 0.6,
    "drawStyle": "line",
    "fillOpacity": 0,
    "gradientMode": "none",
    "hideFrom": {
    "legend": false,
    "tooltip": false,
    "viz": false
    "insertNulls": false,
    "lineInterpolation": "linear",
    "lineWidth": 1,
    "pointSize": 5,
    "scaleDistribution": {
    "type": "linear"
    "showPoints": "auto",
    "showValues": false,
    "spanNulls": false,
    "stacking": {
    "group": "A",
    "mode": "none"
    "thresholdsStyle": {
    "mode": "off"
    "thresholds": {
    "mode": "absolute",
    "steps": [
    "color": "green",
    "value": 0
    "color": "red",
    "value": 80
    "overrides":
    "options": {
    "legend": {
    "calcs": ,
    "displayMode": "list",
    "placement": "bottom",
    "showLegend": true
    "tooltip": {
    "hideZeros": false,
    "mode": "single",
    "sort": "none"
    "version": "13.3.0"
    "layout": {
    "kind": "RowsLayout",
    "spec": {
    "rows": [
    "kind": "RowsLayoutRow",
    "spec": {
    "collapse": false,
    "layout": {
    "kind": "AutoGridLayout",
    "spec": {
    "columnWidthMode": "standard",
    "items": [
    "kind": "AutoGridLayoutItem",
    "spec": {
    "element": {
    "kind": "ElementReference",
    "name": "panel-1"
    "maxColumnCount": 3,
    "rowHeightMode": "standard"
    "repeat": {
    "mode": "variable",
    "value": "custom0"
    "title": "$custom0"
    "links": ,
    "liveNow": false,
    "preferences": {
    "layout": {
    "spec": {
    "items": ,
    "preload": false,
    "tags": ,
    "timeSettings": {
    "autoRefresh": "",
    "autoRefreshIntervals": [
    "5s",
    "10s",
    "30s",
    "1m",
    "5m",
    "15m",
    "30m",
    "1h",
    "2h",
    "1d"
    "fiscalYearStartMonth": 0,
    "from": "now-6h",
    "hideTimepicker": false,
    "timezone": "browser",
    "to": "now"
    "title": "row_panel_test",
    "variables": [
    "kind": "CustomVariable",
    "spec": {
    "allowCustomValue": true,
    "current": {
    "text": "All",
    "value": "$__all"
    "hide": "dontHide",
    "includeAll": true,
    "multi": false,
    "name": "custom0",
    "options": ,
    "query": "aaaaaaaaaaaa,bbbbbbbbbbb,ccccccccccccc",
    "skipUrlSync": false,
    "valuesFormat": "csv"
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No errors
  • Did you follow any online instructions? If so, what is the URL? Learn Grafana: How to automatically repeat rows and panels in dynamic dashboards | Grafana Labs
Repeating rows in v13 clone the template row, so a good first check is whether the difference is in the row title element itself or in the repeated value. Inspect the first row title and one repeated title in DevTools and compare the element and computed font-size: if all repeated titles share one size and only the first differs, the template row is likely keeping its own heading style while the clones get another.
Two quick isolations help: set the row title to a static string (no variable) and see if the sizes equalize — that separates a variable-rendering effect from a repeat-layout effect; and toggle the row collapse state, since collapsed and expanded header styles can diverge in the new layout engine.
If the static-title test still shows the first title larger, note the exact DOM tags and classes for the first vs repeated titles, plus whether browser zoom or custom theme CSS is involved. Those details usually decide whether it is a styling regression worth reporting with a minimal dashboard JSON.
Hi @jweeda,
This appears to be a bug in Grafana’s row title styling. I found it by reading the row header code, not by running it.
In Grafana v13.3.0, a row is treated as top level only when model.parent?.parent instanceof DashboardScene.
Otherwise it gets the smaller nested row styling (body font size and regular weight).
Your original row (aaaaaaaaaaaa) passes this check.
The repeated copies (bbbbbbbbbbbb, cccccccccccc) are stored inside the source row’s repeatedRows, so their parent is the source row and their grandparent is the rows layout.
They fail the check and get nested row styling. That is why the first row title is larger than the others.
Try placing the repeating row inside a parent row or tab.
The original row and its copies should then use the same nested row styling.
You can report this at Issues · grafana/grafana · GitHub with your dashboard JSON, Grafana version (13.3.0) and screenshot.
Mention that the isTopLevel check in the row header does not account for repeated row clones.
