Grafana Username password invalid
I am using grafana version 9.1.3 on my local machine for learning purposes, I didn’t open grafana since a week. Now when i am opening grafana it’s asking for login password, i did not change credentials but when i am entering the default admin, admin it is showing invalid. I am trying to reset passowrd through mail. but i think i didnt link my mail so not getting any link to reset. is there any way where i can get my all previously created dashboards back and can login in old account?
Hi @garimachouhan,
If you are using Grafana OSS or Grafana Enterprise you can run reset admin password via CLI.
grafana-cli admin reset-admin-password <new password>
If you are using Grafana in Cloud you should send a ticket to Grafana team.
If you are not Grafana Administrator then you should as your admin to reset password for your account:
If you have not lost the admin password, we recommend that you change the user password either in the User Preferences or in the Server Admin > User tab.
Best regards,
ldrascic
Same issues facing in my system, I also change password using CLI but it’s show me successfully changed Admin password but when I tried to login with same credential it’s not working.
Thanks in advance.
Riddhi
hey @riddhis
from this topic:
@codi639 several people have reported the CLI doesn’t work, and the approach you’re taking is fine and can work - but can you report what the error was, why the CLI didn’t work? I’d like to look into making sure the CLI is the easiest/simple way to do this
Hey @davidallen5,
I actually have no idea why it does not work.
I had the same issue as them and find this solution on the topic, so I’m sharing it to make them save time…
The error I actually got is:
root@TIG:~# grafana-cli admin reset-admin-password admin
INFO [08-05|12:16:06] Starting Grafana                         logger=settings version= commit= branch= compiled=1970-01-01T01:00:00+01:00
INFO [08-05|12:16:06] Config loaded from                       logger=settings file=/usr/share/grafana/conf/defaults.ini
INFO [08-05|12:16:06] Config loaded from                       logger=settings file=/etc/grafana/grafana.ini
INFO [08-05|12:16:06] Config overridden from command line      logger=settings arg="default.paths.data=/var/lib/grafana"
INFO [08-05|12:16:06] Config overridden from command line      logger=settings arg="default.paths.logs=/var/log/grafana"
INFO [08-05|12:16:06] Config overridden from command line      logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
INFO [08-05|12:16:06] Config overridden from command line      logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
INFO [08-05|12:16:06] Target                                   logger=settings target=[all]
INFO [08-05|12:16:06] Path Home                                logger=settings path=/usr/share/grafana
INFO [08-05|12:16:06] Path Data                                logger=settings path=/var/lib/grafana
INFO [08-05|12:16:06] Path Logs                                logger=settings path=/var/log/grafana
INFO [08-05|12:16:06] Path Plugins                             logger=settings path=/var/lib/grafana/plugins
INFO [08-05|12:16:06] Path Provisioning                        logger=settings path=/etc/grafana/provisioning
INFO [08-05|12:16:06] App mode production                      logger=settings
INFO [08-05|12:16:06] Connecting to DB                         logger=sqlstore dbtype=sqlite3
INFO [08-05|12:16:06] Starting DB migrations                   logger=migrator
INFO [08-05|12:16:06] migrations completed                     logger=migrator performed=0 skipped=526 duration=800.54µs
INFO [08-05|12:16:06] Envelope encryption state                logger=secrets enabled=true current provider=secretKey.v1
Error: ✗ could not read user from database. Error: user not found
Which is kinda strange since there’s users in the .db file:
sqlite> select * from user;
3|0|admin|admin@localhost||59acf18b94d7e.....aa88a8a6|F3....3R|pz....io||1|1|0||2024-01-15 10:40:51|2024-02-12 08:04:36|1|2024-08-05 10:12:58|0|0
4|0|sa-adding-a-var|sa-adding-a-var|adding a var||g5....OK|b2....ah||1|0|0||2024-07-10 07:52:32|2024-07-10 07:52:32|0|2024-07-10 13:30:54|0|1
hey @davidallen5
I got it now!
Reading the source-code of Grafana leads me to get something very simple.
By default, the command try to run on user-id 0 if no user-id provided. I might be wrong concerning the default user-id value code since I’ve never do Go, but there’s still a default value. In my case, and I think for others people with this issue too, the admin user isn’t in user-id 0 (or the good default value) anymore, which leads to a no user found and that’s logical.
How to make it work:
grafana-cli --homepath "/usr/share/grafana/" -debug admin reset-admin-password --user-id 3 admin
  • The homepath is needed only if you’re not in the installation directory.
  • Change 3 by your actual admin user-id
    • you can find it on the grafana.db, often located /var/lib/grafana/grafana.db
    • select * from user where login='admin';
Could it be possible to change the resetPasswordCommand(c utils.CommandLine, runner server.Runner) function to make it handle different admin user-id?
thanks for posting this. I’m following up with our internal engineering teams to have them take a look at this and see if they can find what’s up and how to fix more systematically.
For me just run the command prompt as admin,
to reset just open the grafana cli directory and just paste the same command > grafana-cli admin reset-admin-password admin
Run cmd as administrator then move to directory and reset the pass using these command
after done just simply restart the grafana service it will work for you. make sure your password in
" " double quote.
