Admin password change
I created a new organization on grafana and added users on it, then when I logged out on grafana as admin to use the new user of the new organization I logged in successful but now the problems comes when I try to login using the admin I’m not able to log in as it tells me the password and username are incorrect. I have tried to change the admin password from the terminal but I’m still not able to change it. What might be the solution to this? Thanks
have you figured this out, @zanderzander007
have you tried resetting with grafana-cli? what version are you on?
@anon70503803 yes I was able to solve it. What I did is I accessed the users from the server then I changed the password in the cli
