I have an existing Grafana system. Is it safe to apply updates? When installing Fedora updates, I get this prompt, but I’m not sure that its safe to answer yes. Please advise.
dnf check-update
grafana 2.3 kB/s | 629 B 00:00
grafana 30 kB/s | 2.4 kB 00:00
Importing GPG key 0x2CF3C0C6:
Userid : “Grafana Labs engineering@grafana.com”
Fingerprint: 0E22 EB88 E39E 1227 7A77 60AE 9E43 9B10 2CF3 C0C6
Is this ok [y/N]:
What happened?
