Grafana unable to fetch InfluxDB data with non default retention policy
Grafana 7.5.6
I am creating a time plot from InfluxDB 1.8 source.
I am creating a new panel and select an InfluxDB source.
  • What happened?
I cannot see any measurements associated with a policy called “signal”. I can only see measurements associated with the default “autogen” policy.
I should be able to see those series.
I can’t take a better screenshot but the field values shows no options and even I type one that should be there such as rssi the time series is empty.
NO
Closing I didn’t notice the default tag in FROM enables me to choose the policy.
