Hello
In Node Red UI Desktop there are swich, slider … to give MQTT odres.
There is that in Grafana ??? Or Grafana is unidirectional
Thank you
Hello
Thank you
If you want to create specific orders you must create your own plugin (or try with AJAX request and disable sanitize html)
