Grafana time series mqtt legend names change
How to change legend names please advise
THANK YOU!!
Hi @,
Welcome to the :grafana: community support forums !!
You can rename the legend with your own custom name by simply using the Overwrite function.
Here are the steps:
1- Select Add overwrite on the right side at the bottom
2- Selection option “Fields with name”
3- Select the field e.g. in your case select Value 1
4- Then click on “Add overwrite property”
5- Select Standard options → Display name
6- Give your custom name here e-g- CPU 1
7- Click Save and Apply on the top right corner
I hope this helps.
Thank you. it works for me.
