Grafana table scrolling
Is it possible to set the scrolling in such a way that the last row is always shown at the bottom?
I am displaying digital signal alarms (0/1) as time series and I would like to see always the last row at the bottom showing without having to scroll down with the mouse.
Thanks
Hi @massaro,
Can I ask, what is displayed on the final row of your table that is so significant? Can you share some screenshots of the issue? And what grafana version are you using?
Hi @anon70503803,
thanks for offering support. My intention was to show the last (newest) row of data at the top pf the table. I did find a solution sorting the table in Grafana.
