Grafana Table – Conditional cell color based on comparison of two columns
In a Grafana Table visualization using version 12.3.1, I have two numeric columns (Column A and Column B).
I want to apply conditional formatting such that:
  • If Column A > Column B, then Column A cell background should be red
  • Else, Column A should remain white (default)
    If yes, please share the recommended approach.
Try this approach:
Looks like Col B value is a static 3.50? If so, would setting the “threshold” value to 3.5 work for you?
Unless the threshold is dynamic and could potentially change?
